Joined: 5/9/2020(UTC) Posts: 18  Location: Cologne Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Hi all! Panasonic has put the FreeD tracking protocol in the UE150 ptz-cam. Probably they will be putting it into other models coming in the future. The camera puts its current ptz coordinates on the network. Feature request: Incorprate FreeD protocol in VMix to control the xyz coorinates and zoom of a multiview layer.
Joined: 4/23/2017(UTC) Posts: 1,493  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I would rather point to famous PTZ vendors to enable the NDI stream to carry these data. With the NDI plugin in ureal engine you just need the NDI feed and can adjust the virtual cam with the NDI PTZ data. It's maybe more a NDI feature that all vendors should support, including vMix, for sure.
