snss
#1 Posted : Wednesday, August 19, 2020 10:22:19 PM(UTC)
snss
Hi!
Since I'm an absolute beginner in vMix, I would like to know:
- if and how can I insert two tickers on top of each other(e.g.:
Ticker 1 [Best Stocks: 1.... 2..... 3....]
Ticker 2 [Worst Stocks: 1.... 2.... 3....] );
- if the speed of the content of the tickers can be adjusted invidually(e.g. text for the 1st ticker will run at a speed of 25, and the 2nd will run at a speed of 30 or greater);
- if the ticker content can be read from a file and how can I do that and please let me know what is the maximum size/characters that can be displayed/read in a ticker.
Thank you.
mavik
#2 Posted : Wednesday, August 19, 2020 10:45:11 PM(UTC)
mavik
Add a title, select a ticker. make your settings
Repeat the same again for the second ticker
use the overlays to display them. Overlay 4 is the top most layer.
snss
#3 Posted : Thursday, August 20, 2020 12:22:30 AM(UTC)
snss
Hi!
Thank you @mavik! Your answer helped me!
I ended by using GT Designer to do what I wanted.
However I run into a small problem. When the text is shorter than the length of the ticker it takes a while until the text is displayed again.
Can the text be repeated automatically when reached the end of the text/line?
Example: Ticker 1 Text: Best Stocks: AAPL, AMZN, TSLA, NVDA. (After ending, this line should repeat automatically without any delays.)
Ticker 2 Text: Worst Stocks: NCLH, DO, CCL, RCL, NBL, ADS, HAL, APA, MRO,
Thank you.
#4 Posted : Thursday, August 20, 2020 12:26:12 AM(UTC)
Thank you.
Sure if the data comes from a data source that is set to automatically advance to the next row ( and set proper time delay)
Ticker type has to be set to add
snss
#5 Posted : Thursday, August 20, 2020 1:17:07 AM(UTC)
snss
@doggy: I entered the text in a separate .txt file, one file per ticker. Everything is read from those files.
Settings in Data Source:
Data Source: xyz.txt;
Table: Text;
Column: Text;
Row: Selected;
Format: {0}
In Title Editor I clicked on clock icon and changed the settings:
Speed: 1
Direction: Left
Type: Add
I reloaded my tickers to see the result. However, I noticed that the Ticker 1 Text text isn't repeated automatically.
Thank you.
#6 Posted : Thursday, August 20, 2020 1:28:38 AM(UTC)
Is your data source set to auto Next and also on loop ?
snss
#7 Posted : Thursday, August 20, 2020 2:01:58 AM(UTC)
snss
Yes, I have Auto Next: 5 seconds. Loop is activated, Update data every: 1000 Milliseconds.
Thank you for the link.
#8 Posted : Thursday, August 20, 2020 2:06:29 AM(UTC)
SO are you telling its all good now ?
snss
#9 Posted : Thursday, August 20, 2020 2:14:48 AM(UTC)
snss
@doggy: nope. I will look into it tomorrow.
These kind of problems occurs when you are a beginner and you don't know how the software works.
Anyway thank you for your time and your help.
#10 Posted : Thursday, August 20, 2020 2:29:42 AM(UTC)
We understand
please make sure you read the helpfiles (search for tickers)
There are more videos on the same channel as the previously posted video
you are combining a few things here
Titles ( specifiaclly tickers)
Data for the titles be it directly edited or using datasources
would advice to play with a ticker by manually changing ticker content (title editor) to get an understanding of the ticker when what does when
snss
#11 Posted : Monday, August 24, 2020 11:47:19 PM(UTC)
snss
Hi!
After some trial and error I figured out a workaround/solution to my problem.
So, the solution was to add one more time the text in the file and then reload it into vMix's ticker.
Below are my settings:
Data Source:
Table: Text;
Column: Text;
Row: Selected;
Format: {0}
Title Editor:
Speed: 1
Direction: Left
Type: changed from Add to Replace
Data Sources Manager:
Auto (button): Activated(Green)
Auto (time): 5 seconds
Loop (button): Activated(Green)
Thank you.
