Joined: 10/15/2019(UTC) Posts: 4  Location: Ivano-Frankivsk
Hi all i make solution for bonding (sender and server) USB modems, WiFi, .... Sdi input and H264/265 codec!!!!’ If you interested write to email vtv3000@gmail.com
Thanks: 21 times Was thanked: 10 time(s) in 9 post(s)
Just to add to this. I have tried Speedify during an event, and had a failure. Have done a lot of testing before and after. It is resilient, in that you can cut a connection, and the upstream keeps going on the other/s. The idea and performance is great, but the main failing is a single point of failure in their VPN's. You can't avoid using their VPN's, and if one of them gets slow throughput, then you slow down all your connections.
To confirm the above comments, about speed, when using Speedify the speedtest.net shows a 20% reduction and pings are double the time. This again, is the VPN in between you and your destination. But if streaming, I can increase the bitrate more with Speedify on, than if it is off. However, for me, the reliability is more important, and the VPN being a single point of failure is a concern.
For bonding mast be 2 device 1 sender 2. Server
Only in this combination bonding will be work !
YouTube, Facebook not have Rtmp server with bonding
You mast restream from own server to YouTube or Facebook
Joined: 4/12/2020(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
I´m currently using openmptcprouter.
you need a VPS and a small Linux PC as your local router. You can use WAN via RJ45 or USB LTE Sticks, also USB Tethering via Iphone is working.
It´s a combination of MultipathTCP and VPN.
Works very solid, currently just SRT has more Loss when using more than one WAN. There i think Settings need a bit more tuning.
