alexjacobs
#1 Posted : Tuesday, August 18, 2020 1:17:59 AM(UTC)
alexjacobs
Just trying out a Brio with vMix. I've read the forum posts regarding the MF option but when I use that option it seems the Brio microphone doesn't come along for the ride. The only option I see under audio sources is 'default'. When I use the regular Brio input the microphone is an option and will work. Anything I'm missing or is this just the way the MF access works?
SportsNetUSA.net
#2 Posted : Tuesday, August 18, 2020 3:28:05 AM(UTC)
SportsNetUSA.net
If using the MF option, you can add the Brio microphone as another input by going to Add Input, then selecting Audio Input. On the drop down you'll see Microphone (Logitech BRIO).
Or you use/choose the Brio without the MF option which as you discovered allows for the microphone to be added via the drop down.
That's the way it seems to work. Probably has to do with bringing true 4K resolution in without excessive latency. Someone on the Forum with more expertise such as mjgraves can explain why the BRIO functions this way.
mjgraves
#3 Posted : Tuesday, August 18, 2020 12:24:31 PM(UTC)
mjgraves
Better yet, use a real microphone. The microphones in Brio are not that great. Their location is far from optimal.
