Htown
#1 Posted : Tuesday, August 18, 2020 3:43:42 AM(UTC)
Htown
Help please can add an shortcut to Input a camera use Stream Deck?
#2 Posted : Tuesday, August 18, 2020 4:34:40 AM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
How would that even be technically feasible, how to know which camera , or even if that camera was even available or connected regardless of being it a regular shortcut or on triggered by a stream deck?
and why?
mppfeffer
#3 Posted : Tuesday, August 18, 2020 4:47:13 AM(UTC)
mppfeffer
What I have done in our setup is to assign a "transition" shortcut (Cut, Zoom, Fly, etc,) that is assigned to the camera's input. As far as assigning it to your Stream Deck, simply create a folder on the Stream Deck for that camera and then assign each shortcut for that camera within the folder by clicking the "Find" button in the upper right corner of the shortcuts menu in vMix and pressing the Stream Deck key that you wish to assign the shortcut to. After that, simply select your shortcut functions in the drop-down menus.
I hope this was helpful.
#4 Posted : Tuesday, August 18, 2020 4:59:19 AM(UTC)
This assuming you have installed the vMix plugin to your stream deck , else you just use the shortcut option or the web option of the SD to do your functions
but the way my little knowledge of English is i understood the question as being able to add a camera as an input into vMix through a shortcut (be it or not using a SD)
mppfeffer
#5 Posted : Tuesday, August 18, 2020 5:58:10 AM(UTC)
mppfeffer
If that's the intent, I don't know how that would (or even if it could) be done.
#6 Posted : Tuesday, August 18, 2020 6:07:27 AM(UTC)
Exactly
and my English is not so bad i do not see a badly worded question
Htown
#7 Posted : Tuesday, August 18, 2020 6:40:04 AM(UTC)
Htown
Well let me be a little clearer. I understand that you will have to select the camera type, input, frame rate, etc., however; I would like to be able to press one button on the stream deck that would take me to the camera option. Then from there I would load up the rest of the details. or Even better if I could be able to press one button that would take me into ADD INPUT.. Now I hope this helps!
Thank you
#8 Posted : Tuesday, August 18, 2020 7:31:37 AM(UTC)
Thank you
Glad i got the intent of the question right :-)
Still wonder though why one would want to add a camera on the fly like this instead of having them all at the ready and tuned (like color) for the production and mixing
Similar Topics
Elgato Stream Deck and vMix (Hardware Compatibility)
by r5dad 2/21/2018 4:53:18 PM(UTC)
