ranz
#1 Posted : Wednesday, August 12, 2020 11:29:03 AM(UTC)
ranz
Hi guys,
Is it possible to select what NIC I want to stream to and perhaps a different NIC I want to send return video for vmix call?
I've got 2 x Internet connections - and I'm wanting to keep the main live stream connection free from vmix call traffic and use the other connection purely for that?
Any ideas?
Cheers,
Ranz
grantcoll
#2 Posted : Monday, August 17, 2020 10:50:41 AM(UTC)
grantcoll
This is a great subject, and one I am keen on also. Currently, you could add an entry to your Routing table in windows, based on the different IP address that vmixcall goes to. But the Windows Routing table is tricky, and does not get saved. The best way would be if you add a +1 and extra comments to my feature request, asking for the ability to select network connections in vmix.
https://forums.vmix.com/...rate-Network-Connections
