We are having very odd behavior with NDI from one vMix to another. Computer one has NDI out set on all outputs and on calls/audio. The outputs work as expected And can be seen on the second computer with outputs. The problem is that vMix calls on the second computer are available as NDI inputs but they have no audio or video. We have checked with NDI monitor on the second computer and it also has no signal. But when we run monitor on the first computer it sees the call NDI. All of this worked in the past weeks.
For clarity, we are running on AWS with very fast machines and fast connections on the same network and subnets.
Thank you for any help! We have an event coming up very quickly and need to solve the issue quick.
This is a port issue. Use the NDI Analysis tool from Newtek, on the Computer One vMix machine, this will show all of the available inputs on the network. This will list the Name: Host IP: Port: Type:
Verify the ports being used are entered in the security group in the AWS account.
Skype NDI issues
(NDI)
by dsolomon
9/26/2018 8:48:48 PM(UTC)
vMixCall and NDI issues
(vMix Call)
by richardgatarski
5/19/2017 6:54:24 AM(UTC)
NDI Issues?
(NDI)
by JonnyNoblett
4/1/2017 5:33:41 AM(UTC)
