VLC stream RTSP H264 AAC no audio
hello
i used the info about setting this up and use the AAC for audio
i do get the stream from vlc into vmix and i see the video but no audio wil play
when i select other audio modes in vlc then vmix popups a error still no audio?
it would be nice to take a windows media server rtsp on port 554 direct in but i can not seem to get this to work matybe becuase vmix does not support wmv9 streams?
Hi, I used VLC to stream video over a LAN to PCs running windows media player. To get the audio to work, I had to tell VLC to transmit two channels of audio. Selecting only 1 resulted in noise being received. There is more info on my blog here http://thomsoneu.blogspo...ay-green-room-video.html
ok i found the sollution is in setting the FFmpeg standards to -2
