Higher CPU usage in .60 build.
Joined: 4/4/2020(UTC) Posts: 16   Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hello. Maybe I am wrong, but when I upgraded vMix from .58 to .60 build I observe performance degradation on my production PC (higher cpu usage and render time). Higher cpu usage on a same vMix presets, higher cpu when playing video ( the same video files which we use earlier) . All windows updates are disable. I didn’t change configuration of my PC. I read changelog for .59 and .60 builds and didn’t find anything about changing in audio and video codecs. Can you tell me what can be wrong? Can you send me link to previous build (.58) ? I getting make performance test and compare results. Maybe I am wrong and results will be the same.
I forgot to say about app crushes. After upgrading to.60 vMix crush 7 times. One or two per day. I have crush dump files for each crushes. Maybe you know how to analyze this files and find a main problem why it crushed
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Maybe the installation file is still in your user's Documents folder. That's where the update program saves them.
 1 user thanked dmwkr for this useful post.
Thanks! I’ll check Documents folder.
Originally Posted by: dmwkr  Maybe the installation file is still in your user's Documents folder. That's where the update program saves them. You was right ! Thank you very much.
