Joined: 4/23/2020(UTC) Posts: 15  Location: Thornhill Thanks: 1 times
Hi folks. I am currently running the 1060 card with 6gb memory and looking to upgrade. We are doing a lot of NDI capturing of laptops as well as SDI camera inputs via a Blackmagic decklink Duo.
I am just curious for anyone using the the 2070 cards and whether the overall thoughts of going to the 2080 is worth it. I am trying to do my research but looking for some direct experience as well as opinions on it.
Hoping this hasn't been talked to death already anywhere.
Just a note that I am thinking of either the 2070 8gb card or 2080 8gb card. Not the TI.
Thanks in advance.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:Hoping this hasn't been talked to death already anywhere. It has ! NDI does not use GPU but CPU so unless you have issues with your current config I'd rather upgrade the CPU
Fair enough.
I know that end of it is mostly cpu. We have an i9 9900 for the CPU so I am really just trying to make sure we are well equipped for all aspects.
I couldn't find the answer I was really looking for but will keep searching.
