How to Capture From ProPresenter?
Joined: 2/18/2019(UTC) Posts: 8  Location: Charleston
For years, we had connected ProPresenter and vMix so that anything that got used on our screens from ProPresenter, we could use as an input in vMix. That connection somehow got disconnected and I'm not sure how to get it back.
It got broken when I connected vMix and PP so that I could put the lyrics from PP on our livestream. Any suggestions on fixing this? Can you connect both at the same time?
Any one able to help with this?
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Hi.
Do you use the latest version of PP? Mac or Windows?
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
With ProPresenter 7 you can create NDI outputs that mirror your main display directly in ProPresenter.
If you're still on ProPresenter 6 you can use vMix Desktop Capture on the ProPresenter computer to get an NDI feed over to vMix.
Joined: 1/8/2021(UTC) Posts: 1  Location: Los angeles
We have been using this for several weeks now and it seems to be going nicely. Upsers
