Joined: 8/8/2020(UTC) Posts: 2  Location: MeppershallBedfordshire
Hello All,
I am new to vMix and as such I may ask some very basic question but for sure I'll only ask when I've exhausted every other avenue to find the information. Currently, live streaming is a hobby but one day I if I'm lucky I'll make a living out it who knows. So with said I am hoping someone can give me a quick guide in audio...
I have a live stream to do next week (my first ever) and as always with these things equipment malfunctions and in this case my Rodecaster Pro has packed up. Before this happened I was planning to use this to mix my audio using some mics to capture general background audio at the reception. Since then I have switched to adding shotgun mics to each of the 3 cameras and then capture video and audio as 3 inputs which I believe is called embedded audio.
The problem I have is that whilst I can see all 3 cameras and all showing the audio I can only seem to get audio from 1 mic. I have watched all the videos and searched for similar issues but I really can't find the answer. It may be it was there and I'm missing it but time will tell.
So if anyone can help I'd really appreciate some help as I've tried everything!
Many thanks in advance
Karl
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Sounds like this could help: Good luck with your first stream!
 1 user thanked dmwkr for this useful post.
Thank you for this I really appreciate your help but it has not solved the problem I'm afraid. I'm stumped on this one I'm going to try changing various settings in the camera just in case it's that.
Many thanks
Karl
