For loop and decimal values
Hi everyone, I'm a newbie here, so thanks to everyone that will spend a little of their time for helping me! Coming to the issue I'm facing at the moment, I'm usign the following script:
dim x as double = 0
for i as integer = 0 to 200 API.Function("SetPanY",Input:=2,Value:=x) x=(x+1)*0.1 console.writeline(x.tostring) sleep(4) next
the only problem is that Vmix does not accept the value that the script generates (as the come in the format "," instead of ".", so jumps straight to integers.
If you have any idea of what am I doing wrong, let me know! :)
That is due to the Windows language settings
Change those settings but will mess up all the other programs use math or replace them in the string before further using
Originally Posted by: doggy  That is due to the Windows language settings
Change those settings but will mess up all the other programs use math or replace them in the string before further using Thank you very much, I will try this way then and let you know!
Change those settings but will mess up all the other programs use math or replace them in the string before further using I made it! it's now working as i wanted. Thanks for the hint!
