	vMix Call
	Audio on Vmix call as a separate channel
                Is there a way to get the audio coming in from a vmix call treated as a separate audio channel? I would like to take just this audio channel and route it through a channel on my mixer for external processing - and send just this audio to a speaker in the interview room.
  Any help appreciated.
 Joined: 5/24/2020(UTC) Posts: 14   Location: Florida Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
                +1  This would be very valuable. If you could choose the output type just as you can on the bus outputs so you can send to Dante for instance. Following this!
 Joined: 8/6/2020(UTC) Posts: 11  Location: United States Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
                Dante virtual sound card. My audio guy refuses to use the internal mix minus. He creates custom mix minus (ifb) for up to 4 callers. We figure with DVSC he can have control of up to 7 callers... BusG is used as a common mix back to all the callers for play outs, TB mic and a directors zoom call, or adding another 7 callers from another vMix workstation:) At that point he has to relinquish local mix minus back to the systems.
	vMix Call
