ELCHAPIN
#1 Posted : Saturday, September 3, 2011 7:28:18 AM(UTC)
ELCHAPIN
Hello everyone
I hope my google translation is understood a little better.
e been working lately with 2 softs by Meneses.
1 - vMix
2 - Easyworkship (link)
and the reason is only to place titles of the Holy Bible
in video services.
The problem is I have to get out of vMix to use the Bible tesxtos only.
Since we use the 2 softs. consuming power of my computer.
I do not like everything else the EasyWorship software.
My suggestion:
I could add something like vMix?
but the cost is separately!
This would be a reason to vMix is ​​one of the softs.
best and all in one.
I think the price will be no problem.
option to add to taste only interested
vMix has many options to add that not all are used.
if the more complicated it is to have Powerpoint and Xaml
I think it would be very, very important to add
Religious and this option is much better if Reyna Valera 1960.
With your new option to make titles, tode be better
and no excuses for using vMix.
I think this topic has already spoken.
Softs mention. free to use, because there are several
of the features or options.
Thanks your patience and attention as always Martin
want to take it into consideration very soon
Hola a todos
Espero mi traduccion google se entienda un poco mejor .
e estado trabajando ultimamente por nesesidad con 2 softs.
1- vMIX
2- Easyworkship ( enlace )
y la razon es solamente por colocar titulos de la Santa Biblia
en los videos de servicios .
El problema es que tengo que salirme de vMIX para poder usar los tesxtos biblicos unicamente .
Ya que usar los 2 softs. consume mucho poder de mi compu .
y no me gusta todo lo demas del soft Easyworship .
MI SUGERENCIA :
podrias agregar algo parecido a vMIX ??
aunque su costo sea por separado !!
Esto seria un motivo mas para vMIX sea uno de los softs.
mejores y con todo en UNO .
Creo que el Precio no sera problema .
para opcion de agregar al gusto solo para Interesados
vMIX tiene muchas opciones de agregar que no todas se usan .
si el mas complicado que es tener Powerpoint y Xaml
creo que seria mucho , mucho importante agregar
esta opcion Religiosa y mucho mejor si es una Reyna Valera 1960 .
Junto a tu nueva opcion de hacer titulos , todeo sera mejor
y no pretextos para usar vMIX .
Creo que este tema ya se hablado .
Mencionamos softs. de uso gratis ; porque hay varios
de esa funcion u opcion .
Gracias tu paciencia y atencion como siempre Martin
deseamos lo tome en consideracion muy pronto .
_______________________________________________________________________________
Capturas
>>> VIDEOS MUESTRA <<<
melody
#2 Posted : Saturday, September 3, 2011 8:17:39 AM(UTC)
Rank: Guest
Groups: Guests
(en)
hi elchapin and martin,
i find something that can helps A LOT on this request...
http://brasilevangelico.wordpress.com/easislides/
or
http://brasilevangelico.wordpress.com/multimidia/
the bibles (microsoft access data base files) are there... martin, if is possible, just implement a custom overlay that makes possible choose the bible file (translation), book, chapter and verse (drop down boxes).
thank you elchapin by this request. +1 vote.
regards,
melody
(es)
hola, elchapin y martin
he encontrado algo que puede ayuda MUCHO a esta petición ...
o
las biblias (Microsoft Access archivos de base de datos) están ahí ... martin, si es posible, simplemente intenta de implementar una plantilla personalizada que permite elegir el archivo de la Biblia (la traducción), libro, capítulo y versículo (menús desplegables).
gracias elchapin por esta petición. Un voto más.
saludos,
melody
#3 Posted : Saturday, September 3, 2011 8:43:51 AM(UTC)
Bible support is definitely on the vMix wishlist, but first the Title feature needs to be built and I am working on that now.
At the very least the Title feature will allow you to easily copy and paste the verses into vMix as required.
One thing that has annoyed me personally is the NIV licensing restrictions, some sources say you have to pay up to $10,000 to license it!
ELCHAPIN on 9/4/2011(UTC)
melody
#4 Posted : Saturday, September 3, 2011 10:05:49 AM(UTC)
Rank: Guest
Groups: Guests
(en)
OMG $10,000? something`s wrong there... easyworship have NIV free download, it maybe a possibility to vmix.
im according with you on tittle feature. maybe copy/paste would be better.
(es)
OMG $10,000? algo se passa mal... puedes bajar directamente de easyworship la NIV sin custos adicionales, esto puede ser una hipotesis para vmix.
estoy de acuerdo contigo en la función de titulos. talvez copiar/pegar sería mejor.
ELCHAPIN
#5 Posted : Sunday, September 4, 2011 6:09:53 AM(UTC)
ELCHAPIN
Thanks for your attention
is a tool proved necessary,
temporarily staying with me copy and paste
that gives me 2 possible problems:
1 - location of text, font and color
2 - The option to make fast online (live)
while searching and copy and paste.
I think we're good, the price you mentioned
10,000. is an abuse,
many soft. free and open for use
but not easy to add another softs.
Http://www.libronix.com/page.aspx?id=home currently use.
Libronix is complete, fast and easy but it is paid
Well were in copy and paste
Thank you.
God enlighten you a comfortable and easy solution Martin
Morales
Miami Florida USA
>>> FUENTE LIBRONIX <<<
Gracias por su atencion
es una herramienta muy nesesaria ,
temporalmente me quedo con copie y pegue
que me da 2 posibles problemas :
1- La ubicacion de texto , tipo de letra y color
2- La opcion de hacer rapido en linea ( En vivo)
mientras busca y copia y pega .
Creo que vamos bien ; el precio que mencionas
de 10,000. es un abuso ,
hay muchos soft. libres y abiertos para su uso
pero no faciles de agregar a otro softs .
Actualmente uso http://www.libronix.com/page.aspx?id=home .
Libronix es completo , rapido y facil pero es de paga
Bueno quedamos en copie y pegue
Gracias .
Dios te ilumine una comoda y facil solucion Martin
Morales
Miami Florida USA
>>> FUENTE <<<<
ELCHAPIN
#6 Posted : Sunday, September 4, 2011 7:04:04 AM(UTC)
ELCHAPIN
I want to share some free bibles
free or open distributive;
1 - It is self-installing
2 - one more, full installation
both are free, proven and safe
Copy Paste in the future
vMIX2011 all in one.
them down with confidence from mediafire
only see advertising, fast download
I hope they serve, in both senses
The link below:
>>> Descarga aqui <<<
Quiero compartir unas biblias gratis
de libre o abierta distribuicion ;
1 - Es autoinstalable
2 - Otra mas , de Instalacion completa
ambas son gratis , probadas y seguras
para COPIAR Y PEGAR en el futuro
vMIX2011 todo en uno .
bajarlas con confianza desde mediafire
solo veran publicidad , Descarga rapido
espero les sirva , en el doble sentido
Los link aqui abajo :
>>> Descargarlas desde aqui <<<
Original link
http://www.mediafire.com/?fqo8zgioo69za25 .
ELCHAPIN
#7 Posted : Monday, September 5, 2011 3:14:10 AM(UTC)
ELCHAPIN
melody wrote:
(en)
or
regards,
melody
(es)
o
saludos,
melody
Thanks Melody
looks good, is equal to Easyworkship
download it but not in Spanish Language.
Search and nothing.
will try to use it in English,
does not bring bibles added, songs.
Not to make the sta. Copy and paste Bible.
grateful
Morales
Gracias Melody
se ve bueno , es igual a Easyworkship
lo descargue pero no aparece en Idioma Español .
Busque y nada.
tratare usarlo en Ingles ,
no trae biblias agregadas , canciones .
No esta para hacer de la sta. Biblia Copiar y pegar .
agradecido
Morales
melody
#8 Posted : Monday, September 5, 2011 5:54:15 AM(UTC)
Rank: Guest
Groups: Guests
hi elchapin,
easislides is an alternative to easyworship, but with some limitations.
these bible files can be open with microsot access. unfortunately, the options copy/paste are not available.
regards,
melody
www.espiritosanto.cc
ELCHAPIN
#9 Posted : Monday, September 5, 2011 9:36:52 PM(UTC)
ELCHAPIN
thanks
I still have multi-language Libronix is easy and has many books.
and the best in milesegundos for any information or verse;
I recommend it.
for the moment seems only interested us.
I think it will be much demand in the Churches, when they are working.
and look at their function.
Martin expected to make the function of copy and paste.
option to paste a new title
news and notices.
pending developments
Morales
__________________________________________________________________________________
Gracias
sigo con libronix es multi-idiomas facil y tiene muchos libros .
y lo mejor en milesegundos busca cualquier dato o versiculo ;
te lo recomiendo .
por el momento parece solo a nosotros interesarnos .
creo que sera mucha la demanda en las Iglesias , cuando ya este trabajando .
y miren su funcion .
a esperar que Martin haga la funcion de COPIA Y PEGA .
una nueva opcion para pegar titulos
noticias y avisos .
en espera de las novedades
Morales
