shinyidol
#1 Posted : Friday, July 31, 2020 1:08:50 PM(UTC)
shinyidol
We have been doing some experiments with vMix Call and NDI to record each call independently for post production, but the scaling resolution is really messing things up. Is there a way to force resolution or at least a limiter? Going from 720p to 240p dynamically is throwing things off.
Follo
#2 Posted : Saturday, August 1, 2020 11:45:26 AM(UTC)
Follo
Germany
Was thanked: 14 time(s) in 8 post(s)
I assume that your callers are connected via a browser. vMix Call uses the WebRTC protocol, so the resolution is automatically regulated via the browser/protocol, depending on the bandwidth.
You can try to set the connection manually (right click on Caller in vMix, advanced settings, remote guest bandwith settings), but the better way is probably if you implement the calls via vMix to Vmix. Then the quality is much better than using a browser.
Another possibility is offered by srt. However, the port requires approval / forwarding. But with srt you can set a fixed latency.
I hope it helps you a little.
shinyidol
#3 Posted : Saturday, August 1, 2020 12:47:25 PM(UTC)
shinyidol
I thought the settings was for the broadcast back to the remote guest, not changing the incoming resolution.
