Windows 10, main computer monitor and an HDMI output going to a TV as a talking head monitor for interviews.....I need to output vmix call to that monitor for the duration of the interview.....there is a live camera on the monitor.....this setup is common in the Covid age- but I cannot figure out how to get this to work.
Any help appreciated.
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Set Fullscreen to display 2. Then in the Fullscreen drop down, set the input you want to send there.
Originally Posted by: Vince Beck  Set Fullscreen to display 2. Then in the Fullscreen drop down, set the input you want to send there. Will this affect recording?
No, the main recorder is set to record your program feed by default. The Fullscreen output is just a preview, often used as Multiviewer.
Thank you....I will be back at it tomorrow. Waiting for some lighting to show up, and a software licence for audio....tomorrow I complete and test this setup....
This does not work.....I am sending an image of a screen into itself so I get the video echo when used as above What I need is a fully separate output to the monitor with the input defined as only the Vmix call....is this possible?
Did you click on the down arrow next to the Fullscreen icon and picked the VMix call input? That should send that input full screen to the monitor at all times.
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
 Image1.jpg (93kb) downloaded 2 time(s).Here's an example. You can see that Output 2 is showing Input 7.
That worked....onto next problem..thank you.
