Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi all I want to know if its possible to make for example a virtal set with 2 ou 3 windows BUT NOT rectagular
| \ | | \ PIC 2 | |PIC 1 \ | | \ |
For example
Thanks a lot David
Thks you can help me give me a sample to see anlyse the html file please?
Your question:I want to know if its possible to make for example a virtal set with 2 ou 3 windows BUT NOT rectagular.
My answer: yes. Everything is possible if you want. Square, triangular, round, oval, hexagonal, etc. Under vMix VirtualSets, see how the XML Config (not HTML) is structured.
For example, Download Virtual Studio 115 here (it's free). Screen oval.
ok thanks i will check and try to make for me my "design"
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
One can use Key/fill inputs or uv maps or mask them or rotate-crop rotate (with NDI)
I thought I had seen this question before. Oh, yes here. Why open a new post again?
Why does it take 8 responses before being specific and wasting ---- time
 vMix Capture 30 juillet 2020 14-32-27.png (2,125kb) downloaded 1 time(s).
