Shortcut and activators behaviour
Joined: 12/20/2016(UTC) Posts: 187   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I noticed a different behaviour in shortcut an activators when I select "local". After a list is completed, if I select "local" in the first item of the list in shortcut, it stays there, if I do the same in activators, that item goes to the end of the list. I think that the behaviour in shortcut is right. Is it possible to have the same in activators? Thank you in advance.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
I believe you should post this in the Feature Request section Spino !
Originally Posted by: DWAM  I believe you should post this in the Feature Request section Spino ! Done. Tha administrator can remove this post here.
