#1 Posted : Tuesday, July 28, 2020 11:12:44 PM(UTC)
New version of NDI Tools is available for download. Includes NDI 4.5.3 libraries, the digital signature of the installer is dated July 22, 2020 if you want to verify.
• NDI® SDK documentation improvements, particularly for cross platform use.
• Virtual camera driver will be significantly faster in most common scenarios and uses significantly optimized scaling and format conversion into the target resolution. In practice this will result in better quality and lower CPU usage when using this in most messaging applications.
• Big improvements to Studio Monitor for touch use. Improved usage around the drag and use of the KMV indicator around the screen.
• Potential fix for rare HX v1 problem with hardware decoding.
http://ndi.tv/
