Joined: 7/20/2020(UTC) Posts: 15   Location: Henfield
Hi all, Having an issue with VT audio over SDI at the moment, where the audio will become very "choppy", this can happen as a VT is played or part way through. Stopping and re-starting the External Outputs seems to solve it at the time, but is far from ideal to kill the main PGM out mid-show even for a couple of seconds. Firstly, here's a link to an excerpt from yesterday, recorded externally. The setup is as follows; ProductionPC:- Ryzen 3700X 16Gb RAM 6Gb 1660ti Media coming from internal 2nd SSD Blackmagic Decklink Duo 2 (one set of inputs paired for key/fill) Windows 10 - 1909 vMix Pro 23.0.0.59 x64 External 1 - Key/Fill Output External 2 - Output Audio Output Master - Blackmagic Device At the time of the above clip, the VT file is in a List, it's h.264/MP4 approx 25Mbps Render times were 0-3ms, GPU Mem 47%, both CPU usage below 10% Any ideas appreciated. Many thanks Matt
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Do you also have Master configured as Audio Channel for you External Output? Try setting Audio Output Master to Enabled, or a different device.
