Peter1000
#1 Posted : Monday, July 27, 2020 9:18:33 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
vMix Script Remote
This small, Windows-PC only, software starts fixed vMix scripts. The script names cannot be changed.
Each button calls up a script when pressed and calls up another script when released.
scriptpanel image.PNG (21kb) downloaded 14 time(s).
The scripts must exist in vMix, This panel does not create any scripts. It recalls them only in vMix.
The program is a single EXE file and needs no installation.
If you run it on the same computer as the vMix program, set the IP to "localhost". (Without quotation marks...)
If the program is running on another computer in the same network, set IP to the IP of the vMix computer.
It also runs over WLAN and needs very little traffic.If you run it on the same computer as the vMix program, set the IP to "localhost".
Please report any errors. My system works as described, further applications are not tested :-)
ATTENTION. Use only lowercase for the scriptnames.
Button1, press, calls script1down
Button1, release, calls script1up
Button32, press, calls script32down
Button32, release, calls script32up
Button 25 – Button 32 have holding function
With this panel, intercom and monitoring, or any script-driven vMix-thing can be easily called.
Download Program and Manuals Here
thanks 4 users thanked Peter1000 for this useful post.
doggy on 7/27/2020(UTC), dmwkr on 7/27/2020(UTC), DWAM on 7/27/2020(UTC), nikosman88 on 12/3/2022(UTC)
LeeL
#2 Posted : Monday, August 30, 2021 2:58:59 AM(UTC)
LeeL
Peter, I am reading the pdf to determine if I can apply any of these techniques.
So thanks. Even it is not what I need, I always learn something new from looking at other approaches and code.
Appreciate the link. I will let you know what happens.
Lee
