3rd Party Software and Development
how to collapse an entry using direct access or script
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Greetings everyone, my question is, how to collapse an entry using direct access or script, I have reviewed the help of the functions, in all their categories and I could not find a function that says something like that of contracting, I would like to contract an entry and also of a category or maybe all at the same time, can it be done? I know some script maybe it should be done there but what worked, or is there still nothing like that to do it in vmix.? i used google translate to send this ..
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Papo  Greetings everyone, my question is, how to collapse an entry using direct access or script, I have reviewed the help of the functions, in all their categories and I could not find a function that says something like that of contracting, I would like to contract an entry and also of a category or maybe all at the same time, can it be done? I know some script maybe it should be done there but what worked, or is there still nothing like that to do it in vmix.? i used google translate to send this .. Can you please try to explain what you mean by collapsing an entry ?
I guess he means "Right click the title of an input to collapse it"
AFAIK it's not possible remotely... Maybe with AHK? Assuming you know the position of the input first
Originally Posted by: DWAM  I Maybe with AHK? Assuming you know the position of the input first Would be hard as one can not pinpoint any input by name or code except for mouse position (inputs are seen as buttons with the same ClassNN)
greetings thanks for your response, so at the moment there is no function of the vmix itself that does that collapse the entries or one in particular, :(
Originally Posted by: Papo  greetings thanks for your response, so at the moment there is no function of the vmix itself that does that collapse the entries or one in particular, :( People have been using vMix for years and years and using right click on the input name to collapse it without any fuzz, and you wan to tmake it harder using shortcuts or so where you would have to specify which one(s) etc ? if you dont want to see them choose an empty category
