Hallaman
#1 Posted : Friday, July 24, 2020 3:47:51 PM(UTC)
Hallaman
Hi All,
Just getting started with scripting and trying to find the syntax for returning the bus on/off states for inputs. Does anyone have that info??
I can't seem to find what I need to pass in the script to find the bus states.
Cheers,
JB
#2 Posted : Friday, July 24, 2020 4:20:41 PM(UTC)
one can check a audio bus state from the API xml (Muted true or false)
From an input data one can check which audiobusses the input is on or the input is muted or not
check the "scripting for dummies" posts for tips on reading the API XML
Hallaman
#3 Posted : Friday, July 24, 2020 4:51:35 PM(UTC)
Hallaman
Thanks Doggy,
I found the audiobusses reference in the XML. I'm not well versed in VB.net. How would you parse the return from audiobusses into an if elseif scenario?
I'm basically creating a single button that toggles the Audio Bus assignment on an input. I need to do this for a couple of busses on a couple of inputs.
ie: Bus A and B on Input 3, Bus C and D on Input 4 etc.
I would use a find in C++ can you do something similar in VB.net?
Cheers,
JB
