avcomguy
#1 Posted : Wednesday, February 5, 2014 5:57:59 AM(UTC)
avcomguy
Ireland
Again - this software is top notch ! I have a crew eager to get their hands on it, and I'm eager to let them ! - just need to iron out this one.
IF we add a camera, set de-interlace to 'none'.
Send video on HDSDI to projector.
Image perfect, panning/tilting/zooming - until we add an effect (eg 2 cameras side by side).
If we re-set the input, with interlace to 'blend'.
On HDSDI - jitter (but the effects are fine).
The same jitter we see on HDMI from primary display card.
Hope this helps to explain what we're seeing - and (hopefully) inspire a 'Eureka' moment.
We really would like to nail this - the unit is great/perfect as a web broadcaster. At the moment I couldnt use it as a live show machine.
Many Thanks Again,
Pete
#2 Posted : Wednesday, February 5, 2014 6:59:39 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Sounds like you want to preserved the full frame rate rather than deinterlacing.
Have a look at the following knowledge base article:
http://www.vmix.com.au/k...rlaced-sources-supported
avcomguy
#3 Posted : Wednesday, February 5, 2014 8:21:23 AM(UTC)
avcomguy
Ireland
You truly are the king of kings !!
That nailed it.
Thanks !
Pete
