ARiggs
#1 Posted : Friday, July 24, 2020 5:53:10 AM(UTC)
ARiggs
I have three 4k 60p cameras that I plan to use with vMix Pro on a Dell T5810 (Intel Xeon E5-1630v3 3.7Ghz, 32GB RAM, 256GB SSD, NVIDIA Quadro K2200)
Based on my computer’s specs, I need help determining which method of input will work best with vMix:
1. Converting my 4k camera signal to NDI (not NDI|HX) then adding the NDI sources in vMix. Would use the Bird Dog 4k Quad.
2. Install a PCIe capture card into the computer to receive SDI from the camera then add sources from the capture card. Would use the Blackmagic Design Decklink 8K Pro Cinema Capture Card
Anyone have any advice on what method of input might be best for vMix Pro running on my computer? I'm brand new to vMix, so any help is appreciated!
Thanks!
#2 Posted : Saturday, July 25, 2020 11:45:46 PM(UTC)
@ ARiggs
SDI would be my choice.
spino
#3 Posted : Sunday, July 26, 2020 12:14:29 AM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
Originally Posted by: IceStream Go to Quoted Post
@ ARiggs
Mine too.
