ArmandTanzarian
#1 Posted : Thursday, July 23, 2020 1:41:42 PM(UTC)
ArmandTanzarian
I am planning to use vmix on a hp omen 17 inch laptop with a nvidia2060 graphics card but my question is how do I connect my blackmagic hyperdeck shuttle with ssd drive to the laptop to record my program out?
The laptop only has one thunderbolt 3 port in which I have connected an enclosure with a decklink capture card.
Is it possible to connect the hyperdeck via hdmi through the display port? To record the vmix output?
Thanks in advance any help greatly appreciated.
#2 Posted : Thursday, July 23, 2020 5:22:01 PM(UTC)
It's way much easier to record internally in vMix but
yes you can either :
- use the Fullscreen HDMI out of the laptop to an HDMI/SDI converter going to the Hyperdeck (no need for a capture card here)
OR
- use the EXTERNAL renderer with the capture card
It's all explained in the manual : https://www.vmix.com/help23/ExternalOutput1.html
