coyera
#1 Posted : Wednesday, July 22, 2020 6:05:31 PM(UTC)
coyera
Argentina
I've search in the forum for a solution to this error, but I didn't find any.
I have all my drivers up to date, and I know my laptop is old.
My PC
AMD Athlon Dual-Core QL-60 1,90GHz
4,0 GB RAM
Windows 7 x86
NVIDIA GeForce 8200M G
And when i try to Input a Video the error is this:
Could not Configure VMR
AddNewInput.I_VMR
Error al crear una instancia del componente COM con CLSID {51B4ABF3-748F-4E3B-A276-C828330E926A} desde IClassFactory debido al siguiente error: 80040273.
See images attached.
Please help.
Thanks.
My PC 01.JPG (35kb) downloaded 0 time(s). DXDiag Pantalla.JPG (59kb) downloaded 0 time(s). vMix Diag.JPG (55kb) downloaded 0 time(s). vMix Version.JPG (75kb) downloaded 0 time(s). vMix Error 80040273.JPG (35kb) downloaded 0 time(s).
#2 Posted : Thursday, July 23, 2020 5:27:14 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
I don't think such an old PC with an Athlon CPU meets the requirements for vMix
vMix needs Intel CPU (or newer AMD processors) and an nVidia graphics card (GPU) as clearly indicated on vMix website : https://www.vmix.com/sof.../supported-hardware.aspx
coyera
#3 Posted : Friday, July 24, 2020 3:06:18 AM(UTC)
coyera
Argentina
Thank you for your answer.
#4 Posted : Friday, July 24, 2020 3:10:56 AM(UTC)
You're welcome
There is also a problem with the 32 bits OS. I'm not sure whether vMix still supports 32 bits... Btw I guess your machine is not able to run vMix which requires a powerful and up-to-date system. Live production video is demanding on the sytem.
Good luck !
