	Set Audio File Starting Point
 Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
  Can we set an Audio File starting point? For example I have Music.mp3, and I added it to a vMix Input named MUSIC. I also added another Background, so when I cut the Background Input, I want to create a trigger that play the music at certain point (for example 03:13/05:04).
  Thanks in advance.
 Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
                This is not possible at the moment.  BUT there is a very stupid workaround!Rename your Music.mp3 to Music. mp4 and then import it to the vMix, as you can see, music still works, but now you can mark in/out points the same way as for videos, seeking and right-clicking to set Mark In / Out.  https://prnt.sc/tmd20s
