Forum Rank:: Newbie
Joined: 11/18/2013(UTC) Posts: 7 Location: Calgary, Canada
A feature request:
For Vmix Replay to record the individual audio from each camera source, and have an option for Vmix to output the audio from the current camera during output to either replay channel. This would include a new dropdown item for "Playback Audio Source" to include a "Current Camera" option alongside Master, cam 1-4.
This would allow Vmix to function better as a digital VTR system, recording interviews and other unrelated sources (with their own unique audio, such as interviews) for use later in a show.
Let me know if you need any clarification. Cheers!
+ 1
Seems to me this has been requested before, or at least something very similar.
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
+1
This is an excellent suggestion and I thought of making it on many occasions. It would be especially useful for people trying to use the replay on a vMix production machine
+1
I struggled for a while with this thinking I was doing something wrong - surely the replay audio would follow the selected angle as a default behaviour? Obviously not :(
What's interesting is that if you open up one of the recorded clips it has the correct audio. So the correct audio is being recorded with each replay input but unfortunately only the 1 Playback Audio source as selected when vMix replay is setup is used for the output through vMix.
+1
for us, we need two option
a) Audio follow angle b) Audio fix to one of the 4 cameras
any news on this feature is it possible in 20.0.0.42? now
This would be a tremendous feature. ALSO, Instant Replay needs the option to cut/mute the audio automatically when playback is anything but 100%. I use IR as a stand-alone replay system and would like to use the "nat" sounds for replays at 100%, but, do not want the slo-mo audio when performing a replay at say 70%.
Would be great to be able to choose an audio input, not just camera audio, too
This would be a really great feature in order to show a recorded interview or timeout during sports together with audio.
I'd also like to bump this. This would be an absolute killer feature! If not possible, a shortcut command to switch between the audio input.
The use case here would be an esports stream with 2 observer feeds. Currently, with only 1 audio channel being recorded (Observer A), a replay playback of Observer B will not have the audio associated with this feed and it could be noticeably distracting for the viewer as this might be following completely separate action than Observer A.
Thanks!
Pretty sure this is going to be a part of vMix 24 :-)
