VideoE
#1 Posted : Wednesday, July 22, 2020 3:46:29 AM(UTC)
VideoE
As a vMix noob, I'm curious as to whether when sending key/fill grfx from vMix whether vMix generates its' own greyscale image from the title designer for a linear key? And am I correct in assuming, I need a seperate capture card to output that alpha channel/functionality, no way to do that say using the 2 fullscreen outputs? Right now I have the HD version, no way to examine alternatives.
#2 Posted : Wednesday, July 22, 2020 4:13:39 AM(UTC)
@ VideoE
Key and fill support is only available with select I/O Blackmagic Capture Cards.
https://www.vmix.com/help23/KeyFill.html
VideoE
#3 Posted : Thursday, July 23, 2020 12:51:18 PM(UTC)
VideoE
Thanks for the interest and the heads-up. Partly, the question was whether the alpha in the .png generated by the GT title designer would work as a linear key signal for the ATEM. I extracted the 'alpha' in a GT title as a greyscale image in GIMP. Used the color/fill feed from vMix and the greyscale image was brought into the ATEM via the media player and voila, a clean key with subtle transparencies.
