Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
I took this screenshot... I'm getting "GPU Overloaded" warnings, but the task manager makes it look like the GPU isn't anywhere near its limit. This is running on AWS EC2 (g4dn.16xlarge). There are calls, NDI sources (and outputs), and most everything else is a PNG over a looping mp4.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
Originally Posted by: IceStream  Ice, Thanks for your reply. It's not GPU memory that I'm worried about. That's sitting at 56%, and not a concern at all. The GPU performance, on the other hand, seems to be an issue. According to Task Manager, we're only using ~48% of the GPU... but I'm getting "GPU Overloaded" warnings.
Like many video processing applications, vMix make heavy use of 2D functions of the GPU. Not so much use of the 3D facilities. As such, that very general GPU usage indication may not be meaningful or insightful.
Is the GPU shared via nVidia Grid? Or is it 100% dedicated to your instance?
Originally Posted by: simond83  Is the GPU shared via nVidia Grid? Or is it 100% dedicated to your instance? Yes, this is a dedicated instance with its own Tesla T4.
Originally Posted by: mjgraves  Like many video processing applications, vMix make heavy use of 2D functions of the GPU. Not so much use of the 3D facilities. As such, that very general GPU usage indication may not be meaningful or insightful. Thanks for your knowledge. So is there no accurate way to measure how hard a GPU is working when running vMix?
Originally Posted by: Geoff B  Thanks for your knowledge. So is there no accurate way to measure how hard a GPU is working when running vMix?
I would try GPU-Z. It's likely more robust than the Windows built-in stuff.
Originally Posted by: mjgraves  I would try GPU-Z. It's likely more robust than the Windows built-in stuff. Thanks! I'll give it a shot.
Originally Posted by: Geoff B  Yes, this is a dedicated instance with its own Tesla T4.
The T4 is a special processor designed for cloud/AI. https://www.nvidia.com/en-us/data-center/tesla-t4/While it has a decent number of 'cuda cores, it's not clear how it performs in the traditional GPU role. It's not really built for that. What they describe with respect to video performance is high-volume decoding, because stream analysis is part of AI training.
Originally Posted by: mjgraves  While it has a decent number of 'cuda cores, it's not clear how it performs in the traditional GPU role. It's not really built for that.
What they describe with respect to video performance is high-volume decoding, because stream analysis is part of AI training. Totally agreed. If I had a better option, I'd use it.
Thanks: 21 times Was thanked: 10 time(s) in 9 post(s)
I wonder if the CPU is the cause, or a consequence. The Rendering is way too high. It should be below 20ms. Perhaps there is some other problem, making the Rendering bottle neck and the GPU overload could be a result. I notice that you are sending on ethernet at about 160Mbps and receiving at 697Mbps. That is a huge amount of data transfer speed. Perhaps that is some of the trouble.
Originally Posted by: simond83  We have tried multiple-GPU instances. Nothing we did improved performance. We tried attatching the virtual display -- which feeds TeamViewer or Teradici -- to one of the GPUs, and assigning vMix to the other. While it looked like the workload was being divided between the two GPUs, we still had the performance issues. We haven't tried the Google Cloud yet, but we plan on trying this out next month.
Originally Posted by: grantcoll  I wonder if the CPU is the cause, or a consequence. The Rendering is way too high. It should be below 20ms. Perhaps there is some other problem, making the Rendering bottle neck and the GPU overload could be a result. I notice that you are sending on ethernet at about 160Mbps and receiving at 697Mbps. That is a huge amount of data transfer speed. Perhaps that is some of the trouble.
The high data is due to NDI. Each stream is about 100Mbps. These machines are capable of 50Gbps transfer, so it seems unlikely to me that bandwidth is the issue.
What's your machine spec? CPU/Ram etc?
SSD or HDD?
Originally Posted by: simond83  What's your machine spec? CPU/Ram etc?
SSD or HDD? This is a virtual machine (one of many) running on AWS EC2. It's a g4dn.16xlarge: 64 vCPUs 256 GB RAM 1x300GB NVMe for system 1x900GB SSD 50GBps Network Throughput
