Virtual PTZ + Virtual Set : is it possible?
Hello all,
It seems that it's not possible to use a virtual PTZ on top of a virtual set or multiview setup, is that correct or am I missing something?
Specifically, I'm looking to use the UVMAP features of the virtual set to undistort a 4K wide shot (gopro style). I would then like to pan and zoom inside the undistorted live image, which doesn't seem to work, no matter what combination I've used.
It would also be very useful for regular virtual sets, instead of the current 4 "static" presets.
Thanks for your help.
Eric
NDI route
output virtual set or multiview as NDI and bring back in as input, that will work for your virtual PTZ
Thank you. I'll try that.
It would be nice to be able to do it internally though.
Best, Eric
