Joined: 7/17/2020(UTC) Posts: 7  Location: Rockville Centre Was thanked: 1 time(s) in 1 post(s)
I am trying to capture audio from a remote desktop capture. The other computer is on the same network as my Vmix computer, but I'm only getting video from it.
I'm trying to capture a zoom call which I'm sending the vmix program into, and need the audio with mix minus program to return into vmix.
The set up: Zoom computer is a mac pro trashcan.
Vmix is a Dell xps
In fact I have 2 other Macbook pros, that vmix desktop capture does not send audio from either. Is it a mac thing?
Any thoughts?
Desktop capture should be able to send audio as well.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
I had a similar situation on MS Windows 10. The NDI's incoming audio was treated as a microphone input by the OS. I had to permit somewhere in the OS security settings to listen to the microphone inputs.
Regards, Andy
