Joined: 3/25/2019(UTC) Posts: 38  Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Is it possible to send the overlays to output 2?
The output of the mixer is send to output 1 and an input is send to output 2. When I enable an overlay i see it only on output 1.
Does someone have an idee to get this working?
Kind regards
Koen Deschepper
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
add your overlay input as a layer in the input you're sending to Output2 This can be triggered using the SetMultiViewOverlay command
Thx, I will have a look tomorrow.
I have it working.
Thx DWAM
