Shortcuts for Virtualset Zooms
Hi!
first: thanks for the great support in this forum!
I got a Stream Deck XL and i searching for a solution to get shortcuts for the 4 different zoom settings of the Virtualsets.
Is this possible?
vMix is so unbelievable comfortable - i think there is a solution - always ;-) but unfortunatly i didn't found it. (I have searching here in the forum and in the hotkeys setting - without any success)
thanks in advance!!
Joined: 8/5/2017(UTC) Posts: 580  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
You can use the "SelectIndex" shortcut to switch to one of the 4 zoom settings.
Originally Posted by: raugert  You can use the "SelectIndex" shortcut to switch to one of the 4 zoom settings. PERFECT!! GREAT!! Thank you, raugert!!
