BensonLR
#1 Posted : Tuesday, July 14, 2020 6:23:39 AM(UTC)
BensonLR
In using API commands to switch vMix inputs, it is now required to include the Fade and Duration.
What I am asking for is an API command to switch to a vMix input based upon the input number ONLY.
This would be the same as if I click on the thumbnail input in vMix. Whatever vMix has that input set for, QuickPlay or Overlay or Stinger, whatever just let me send the API command to go to that input Without any other parameters. We already have those inputs set for what fade or overlay we want.
What you have is fine if we want to change the fade rate etc. But I am not needing to change just go to that input 1 or input 2
Larry B
#2 Posted : Tuesday, July 14, 2020 7:46:53 AM(UTC)
Your post does not belong the Feature Request section !!!
Please read this: https://forums.vmix.com/...uest---not-a-feature-one
If Fade is your first transition button, then just use "Transition1"
