strempro
#1 Posted : Sunday, July 12, 2020 12:51:31 PM(UTC)
strempro
Turkey
I'm trying to find a plugin or any other way to show viewers, current playing movie name at the bottom corner. It may get from the file name of the movie.
Do you know any kind of plugin for that feature? I'm also ready to pay for that plugin.
Please advise, thanks.
stigaard
#2 Posted : Sunday, July 12, 2020 4:54:00 PM(UTC)
stigaard
Denmark
Can be done using data sources. Some years ago i made a video on it.
#3 Posted : Sunday, July 12, 2020 5:49:25 PM(UTC)
or very like Stigaard but with vMix script
with a few adaptations
https://forums.vmix.com/...ng-for-Dummies#post73288
Peter1000
#4 Posted : Thursday, July 16, 2020 7:13:28 PM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
This script reads the current title of a playlist and writes it formatted into a field of a title input
In this example I use the title included in vMix " Title 33- On the shelf- Peach.gtzip " and I write the text in the field “Headline.Text”
My list input is Input2.
Please adapt this (title, field and List-input-number) for your project.
I use a list of MP3 audiofiles. These are named as follows:
Anni Piper - Two's Company - 01 - Blues Before Sunrise.mp3
Anni Piper - Two's Company - 02 - Live To Play.mp3
Anni Piper - Two's Company - 03 - Man's Woman.mp3
The goal is to extract a usable name from this string.
The finished script looks like this:
Code:
'script playing now
do
dim xml as string = API.XML()
x.loadxml(xml)
dim word as string = x.SelectSingleNode("//input[@number=[h]'2'[/h]]/@title").Value
word = word.remove(word.Length - 4)
dim wordArr as String() = word.Split("-")
Dim result0 as String = wordArr(0)
Dim result1 as String = wordArr(1)
Dim result2 as String = wordArr(2)
Dim result3 as String = wordArr(3)
Dim result4 as String = wordArr(4)
dim fullname as string =  result1 + " " + result2 + " " + result4
API.Function("SetText",Input:="Title 33- On the shelf- Peach.gtzip",SelectedName:="Headline.Text",Value:=result1)
sleep(1000)
API.Function("SetText",Input:="Title 33- On the shelf- Peach.gtzip",SelectedName:="Headline.Text",Value:=result2)
sleep(1000)
API.Function("SetText",Input:="Title 33- On the shelf- Peach.gtzip",SelectedName:="Headline.Text",Value:=result4)
sleep(1000)
API.Function("SetText",Input:="Title 33- On the shelf- Peach.gtzip",SelectedName:="Headline.Text",Value:=fullname)
sleep(1000)
loop
The script can be started with a shortcut. If the list is cleared, the script stops itself due to an error.
explanation of the different sections
‘do / loop, loops the script infinite
do
‘Reads all API information that vMix has to offer
x.loadxml(xml)
‘Extracts the currently playing name of the list-inputs-2 into the string word
dim word as string = x.SelectSingleNode("//input[@number='2']/@title").Value
‘truncates the last 4 characters of the string word (.mp3)
word = word.REMOVE(word.Length - 4)
‘Splits the remaining string into word parts. In this example the name is divided with hyphens -.
‘Depending on the filename of your list, this may or may not be necessary.
‘Defines the individual word parts as individual strings.
‘Attention: The array must not be larger than it has word parts.[/h]
‘Composes a new string from band name, album and title (fullname)
'If the filename only contains the title, you can use the variable word instead of result1
‘Writes bandname and waits one second
sleep(1000)
‘Writes albumname and waits one second
sleep(1000)
‘Writes title and waits one second
sleep(1000)
‘Writes Fullname and waits one second
sleep(1000)
‘loops back to the beginning
loop
thanks 2 users thanked Peter1000 for this useful post.
doggy on 7/16/2020(UTC), DWAM on 7/16/2020(UTC)
