streaming---pro
#1 Posted : Saturday, July 11, 2020 9:15:48 PM(UTC)
streaming---pro
Germany
I read in the help pages that you should install Vmix on an editing system that is supposed to edit Vmix AVI files. Allthough you don't need a license for Vmix in order to use that codec on an editing PC it's way overkill to install the whole Vmix application for only one codec.
Is there somewhere an installation file to just install the Vmix AVI codec? Or is it possible in the Vmix installer to only select the codec to be installed?
Because Premiere doesn't accept the AVI files from Vmix with the Vmix AVI codec "unsupported file type" right out of the box.
Thanks and cheers
pro.
#2 Posted : Saturday, July 11, 2020 11:46:38 PM(UTC)
Most Adobe Premiere plugins are way bigger than vMix
