vMix Call
Vmix caller not getting mix-minus
Joined: 5/15/2020(UTC) Posts: 2   Location: Minnesota
Hi guy,
When connecting a remote vmix computer to a second vmix computer using the video call function (on the remote vMix, I open the add input> video call> and use the "Connect to call" tab) i am able to hear my self in the audio. I seems like this shold be mix-minus by default, but it is not. Could anyone advise me on how to fix this.
Thank you
Joined: 5/20/2015(UTC) Posts: 493   Location: Copenhagen, Denmark Thanks: 408 times Was thanked: 102 time(s) in 79 post(s)
Do you use a headset on both sides to monitor audio? If not, it could be the cause.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
Can you elaborate on the conditions you're making your test with. I'd like to be sure you just don't have both computers next to each other, with all mics open and no headset.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Open the Audio settings of the microphone input and turn down the headphone volume to 0. When adding the audio input you can also check the "Mute in Headphones" setting.
P.S. This is all in the help files....:-)
vMix Call
