Cali_Chris
#1 Posted : Tuesday, July 7, 2020 2:57:03 AM(UTC)
Cali_Chris
We are doing an event for a client who is a MAC house. All the editors are FCP - and Adobe Premiere. I have done a bit of poking around, looking for a good way to transcode the VMixAvi into ProRes422 on the Mac. Not finding anything promising.
THanks anyone that might have a workable solution. I appreciate your time!
Thanks,
Have a great week.
Chris
#2 Posted : Tuesday, July 7, 2020 3:09:52 AM(UTC)
Why not recording ProRes in the 1st place ?
Cali_Chris on 7/7/2020(UTC)
dmwkr
#3 Posted : Tuesday, July 7, 2020 3:20:59 AM(UTC)
dmwkr
I think ProRes recording takes more toll on the CPU.
https://www.vmix.com/help23/vMixVideoCodec.html
Converting vMix AVI files to ProRes MOV
vMix includes a program called vMix Media Converter that can transcode multiple vMix AVI files to ProRes MOV files.
This program can be located in the Windows Start Menu.
thanks 1 user thanked dmwkr for this useful post.
#4 Posted : Tuesday, July 7, 2020 3:31:33 AM(UTC)
It does for sure but if the computer can do it, there's not need for post transcoding
Cali_Chris
#5 Posted : Tuesday, July 7, 2020 3:47:10 AM(UTC)
Cali_Chris
YES, we have really performant machines. PRORES is deffinately not a good solution. Even with our machines, you get a CPU spike when recording ProRez. IF you tax your processor to much, the records will suffer. Not a good thing when a client is expecting something usable. we are running the show at 1080p @59.94hz.
OUR studio Machine is.
AMD EPIC 7502p External cooling
128GB DDR4 3200MHZ
Nvidia RTX Titan - 24GB Memory
and a bunch of other stuff.
PaulS
#6 Posted : Tuesday, July 7, 2020 10:15:25 AM(UTC)
PaulS
Drat, I came here with pretty much the same situation, was hoping to find an answer. Dropping a comment to follow along and see if anyone has a solution.
#7 Posted : Tuesday, July 7, 2020 4:03:15 PM(UTC)
??? 2 solutions were given already! What do you expect?
YES, we have really performant machines. PRORES is definately not a good solution. Even with our machines, you get a CPU spike when recording ProRez.
I have done ProRes recording multiple times... on a pretty old i7 computer. Never had an issue...
Usually on my system ProRes needs 15 to 25% CPU, on your beast it should be much less with your 32 cores (I have 8)... On my system, it runs fine for hours, even with a 50 inputs project (well designed and optimized, I'm not crazy) while streaming on GPU of course... I don't think the total load load exceeds 55/60% CPU which is still pretty safe.
Not a big deal... Did you just try ?
Unless your project is huge or you need multirecording, I guess your machine can natively record ProRes without a glitch.
Testing is the answer... and the only way to go for you to know...
