Just purchased 4k Software- in the Multiview- all inputs are showing up as 4:3 not 16:9-- the PGM output remains 16:9-- its just the muiltiview windows that are 4:3 aspect ratio
Any thought please?
Thank you
Rob
what's the resolution of your monitor where the multiview output is displayed? what's the setting of the project?
Project is 1080i 59.94 display is set to 1920x1080 seems the input windows are set to SD  multiview #1.jpg (167kb) downloaded 6 time(s).
drag the line between preview/output and inputs down a bit and see the size of the former change Also did you crop the screenshot or is that the full screen display ?
Joined: 5/31/2020(UTC) Posts: 49  Location: California
Redbrick, FWIW I'm having the same problem, 4x3 on the UI, but outputting 16x9. And my project settings are also 1920x1080. Changing the aspect ratio from say 'source' to 'widescreen' actually changes the output AR also and I'm just trying to change the PVW/PGM windows in the UI. Weird...
I ended up reinstalling windows as it was acting funky-= then reinstalled Vmix- problem solved! Thank you for replying- I know that does not help all issues...
