Joined: 3/19/2011(UTC) Posts: 28   Location: France Thanks: 1 times
Hi all, I'm devellopping an external app to automatically generate an EDL file to have the possibility to modify the main live mix in postproduction. And I think important informations are not in the api xml. So I would like to have at least the master frame rate of vMix and the master resolution. I will create a new post in few days dedicated to the EDL generator for vMix.
Loïc
Joined: 9/9/2017(UTC) Posts: 36  Location: Jeffry_Ghost Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
Any new on app for EDL? Would be handy for me :) and for many others
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
You can create a script that writes to a file with every transition you do.
