66 Pages«<4041424344>»
elgarf
#821 Posted : Thursday, July 2, 2020 8:28:35 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
Hi, here is new update.
Universal Title Controller (updated 02.07.2020)
Changelog
02.07.2020:
+ TextField style (only text or filename)
+ All vMix shortcuts are now in Functions.xml
+ [T] - index helper in script builder
! Bugfixes
chococrispis35
#822 Posted : Friday, July 3, 2020 1:57:12 AM(UTC)
chococrispis35
Elgarf
¡Cool!
You are my idol
Thanks for all
chococrispis35
#823 Posted : Friday, July 3, 2020 2:20:22 AM(UTC)
chococrispis35
Elgarf
I already tried the new version, first I remove toggle captions,
then if I select the border of the widget to enter the options, I can enter,
but after a few times the options no longer appear in any widget and I have to restart UTC,
it works a few times and the same thing happens again
thanks
elgarf
#824 Posted : Friday, July 3, 2020 3:22:33 AM(UTC)
elgarf
Russian Federation
@chococrispis35, oops... copy-pasting someday will kill me)
Re-download, please, from previous link.
thanks 1 user thanked elgarf for this useful post.
Chircanu on 7/3/2020(UTC)
chococrispis35
#825 Posted : Friday, July 3, 2020 4:25:50 AM(UTC)
chococrispis35
Elgarf
i try...
send you a email, check
chococrispis35
#826 Posted : Friday, July 3, 2020 5:03:14 AM(UTC)
chococrispis35
Elgarf
Excellent working fine
thanks
ALICIOV
#827 Posted : Tuesday, July 7, 2020 8:48:50 PM(UTC)
ALICIOV
Romania
elgarf, soryy how to create colors using GT Designer on score board vMix Capture 07 July 2020 13-47-47.png (23kb) downloaded 5 time(s).
#828 Posted : Tuesday, July 7, 2020 8:55:17 PM(UTC)
You don't "create colors"
You just use colored images that can be switched on situations
ALICIOV
#829 Posted : Tuesday, July 7, 2020 9:16:22 PM(UTC)
ALICIOV
Romania
DWAN is created in gt designer and changes like this ... but with what is the text created to be able to change the color? Image.png (1,526kb) downloaded 3 time(s).
#830 Posted : Tuesday, July 7, 2020 9:20:45 PM(UTC)
Hi Elgarf
long time no see! Hope you're doing well... and congrats for the latest improvements in UTC, you've done an impressive work.
I'm testing the latest version, many new features, some are just great and it seems UTC is more and more powerful and reliable.
I've seen you've added global variables which I requested for long ago. Not sure how to use them anyway. Can you tell us about them ?
I've set a global variable that I want to use in widgets... What is the syntax for this ?
Thanks and bien à toi
Guillaume
elgarf
#831 Posted : Wednesday, July 8, 2020 2:24:04 AM(UTC)
elgarf
Russian Federation
@DWAM,
In global variables you can store something, that is not changed during controller usage: path for directory with images, for example.
Then you can address this variable by name (it's the left field into global variables list) in script.
Variables are not accessible into text fields, etc. only in button scripts.
When you write text into script parameter, it check "is this text is expression". So, if you have variable with name "TestVar" and value "Hello", and your parameter is
Code:
TestVar + 'Hello'
It will be replaced to "HelloHello"; if you want to see text "TestVar", use
Code:
'TestVar'
Chircanu
#832 Posted : Thursday, July 9, 2020 11:35:52 PM(UTC)
Chircanu
Hello everyone, hello elgarf! I tried today to schedule a registration with UTC (02.07.2020) and I failed. Definitely slipped a small error somewhere, When you have time, please take a look through it. To make the registration I used an older UTC version (17.06.2019). A wonderful day for everyone!
elgarf
#833 Posted : Friday, July 10, 2020 3:14:18 PM(UTC)
elgarf
Russian Federation
@Chircanu,
Now it should be fixed. I've changed a bit exec links, to pass parameters (though it's not used right now), and forgot about clock widget(
Universal Title Controller (updated 10.07.2020)
Chircanu
#834 Posted : Friday, July 10, 2020 10:03:45 PM(UTC)
Chircanu
@elgarf, hello! I tried the new version UTC, the recording start function works well, instead, the record stop function, when it has to act, UTC stops
elgarf
#835 Posted : Friday, July 10, 2020 10:13:13 PM(UTC)
elgarf
Russian Federation
@Chircanu, tried it by myself, but it works for me. Is there log? Or event in windows event viewer?
Chircanu
#836 Posted : Monday, July 20, 2020 9:51:05 PM(UTC)
Chircanu
@elgarf, sorry I posted here, your private message is full. After you see this message, please delete it to keep the forum clean. Thanks for your understanding and help
2020-07-20 14:39:42.5729 INFO Checking vMix server.
2020-07-20 14:39:42.5879 INFO Checking vMix server.
2020-07-20 14:40:02.5744 INFO Checking vMix server.
2020-07-20 14:40:02.5874 INFO Checking vMix server.
2020-07-20 14:40:06.4881 INFO Saving controller.
2020-07-20 14:40:06.4931 INFO Writing widgets.
2020-07-20 14:40:06.4931 INFO Writing window settings.
2020-07-20 14:40:06.5160 INFO Writing global variables.
2020-07-20 14:40:06.5240 INFO Properties updated.
2020-07-20 14:40:09.6299 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:40:09.6349 INFO Trying to send function <> in async mode.
2020-07-20 14:40:09.6349 INFO Function URL is <http://127.0.0.1:8088/api?>.
2020-07-20 14:40:09.7189 INFO Async function sended, result is "<vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.008392334" meterF2="0.008392334">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-35-10 p.m..mp4">False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.01794434" meterF2="0.01794434" headphonesVolume="100" /></audio></vmix>".
2020-07-20 14:40:09.7189 INFO Updating vMix state.
2020-07-20 14:40:09.7319 INFO Creating vMix state form <vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.008392334" meterF2="0.008392334">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-35-10 p.m..mp4">False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.01794434" meterF2="0.01794434" headphonesVolume="100" /></audio></vmix>.
2020-07-20 14:40:09.7319 INFO vMix state created.
2020-07-20 14:40:09.7438 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:40:09.7438 INFO Calculating difference.
2020-07-20 14:40:09.7438 INFO Updating inputs.
2020-07-20 14:40:09.7618 INFO Firing "updated" event.
2020-07-20 14:40:13.3671 INFO Opening properties for widget start copy.
2020-07-20 14:40:22.5756 INFO Checking vMix server.
2020-07-20 14:40:22.5876 INFO Checking vMix server.
2020-07-20 14:40:22.6046 INFO Checking vMix server.
2020-07-20 14:40:32.2426 INFO Saving controller.
2020-07-20 14:40:32.2426 INFO Writing widgets.
2020-07-20 14:40:32.2586 INFO Writing window settings.
2020-07-20 14:40:32.2586 INFO Writing global variables.
2020-07-20 14:40:32.2586 INFO Properties updated.
2020-07-20 14:40:35.7401 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:40:35.7471 INFO Trying to send function <> in async mode.
2020-07-20 14:40:35.7471 INFO Function URL is <http://127.0.0.1:8088/api?>.
2020-07-20 14:40:35.7590 INFO Saving controller.
2020-07-20 14:40:35.7590 INFO Writing widgets.
2020-07-20 14:40:35.7590 INFO Writing window settings.
2020-07-20 14:40:35.7770 INFO Writing global variables.
2020-07-20 14:40:35.7770 INFO New clock widget added.
2020-07-20 14:40:35.7770 INFO Opening properties for widget .
2020-07-20 14:40:36.0764 INFO Async function sended, result is "<vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.1280212" meterF2="0.1280212">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-35-10 p.m..mp4">False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.1280212" meterF2="0.1280212" headphonesVolume="100" /></audio></vmix>".
2020-07-20 14:40:36.0764 INFO Updating vMix state.
2020-07-20 14:40:36.0884 INFO Creating vMix state form <vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.1280212" meterF2="0.1280212">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-35-10 p.m..mp4">False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.1280212" meterF2="0.1280212" headphonesVolume="100" /></audio></vmix>.
2020-07-20 14:40:36.0884 INFO vMix state created.
2020-07-20 14:40:36.0884 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:40:36.1054 INFO Calculating difference.
2020-07-20 14:40:36.1054 INFO Updating inputs.
2020-07-20 14:40:36.1054 INFO Firing "updated" event.
2020-07-20 14:40:42.5708 INFO Checking vMix server.
2020-07-20 14:40:42.5893 INFO Checking vMix server.
2020-07-20 14:40:42.6053 INFO Checking vMix server.
2020-07-20 14:41:02.5784 INFO Checking vMix server.
2020-07-20 14:41:02.5934 INFO Checking vMix server.
2020-07-20 14:41:02.6064 INFO Checking vMix server.
2020-07-20 14:41:02.6174 INFO Checking vMix server.
2020-07-20 14:41:02.6324 INFO Checking vMix server.
2020-07-20 14:41:22.5771 INFO Checking vMix server.
2020-07-20 14:41:22.5861 INFO Checking vMix server.
2020-07-20 14:41:22.6011 INFO Checking vMix server.
2020-07-20 14:41:22.6171 INFO Checking vMix server.
2020-07-20 14:41:35.3846 INFO Saving controller.
2020-07-20 14:41:35.3846 INFO Writing widgets.
2020-07-20 14:41:35.3986 INFO Writing window settings.
2020-07-20 14:41:35.3986 INFO Writing global variables.
2020-07-20 14:41:35.3986 INFO Properties updated.
2020-07-20 14:41:40.7751 INFO Opening properties for widget .
2020-07-20 14:41:42.5755 INFO Checking vMix server.
2020-07-20 14:41:42.5875 INFO Checking vMix server.
2020-07-20 14:41:42.6115 INFO Checking vMix server.
2020-07-20 14:41:42.6185 INFO Checking vMix server.
2020-07-20 14:41:42.6335 INFO Checking vMix server.
2020-07-20 14:41:42.6505 INFO Checking vMix server.
2020-07-20 14:41:52.8910 INFO Saving controller.
2020-07-20 14:41:52.8980 INFO Writing widgets.
2020-07-20 14:41:52.8980 INFO Writing window settings.
2020-07-20 14:41:52.8980 INFO Writing global variables.
2020-07-20 14:41:52.9180 INFO Properties updated.
2020-07-20 14:42:02.5747 INFO Checking vMix server.
2020-07-20 14:42:02.5867 INFO Checking vMix server.
2020-07-20 14:42:02.6027 INFO Checking vMix server.
2020-07-20 14:42:02.6187 INFO Checking vMix server.
2020-07-20 14:42:05.5655 INFO Saving controller.
2020-07-20 14:42:05.5725 INFO Writing widgets.
2020-07-20 14:42:05.5725 INFO Writing window settings.
2020-07-20 14:42:05.5855 INFO Writing global variables.
2020-07-20 14:42:22.5763 INFO Checking vMix server.
2020-07-20 14:42:22.5883 INFO Checking vMix server.
2020-07-20 14:42:22.6043 INFO Checking vMix server.
2020-07-20 14:42:22.6193 INFO Checking vMix server.
2020-07-20 14:42:22.6343 INFO Checking vMix server.
2020-07-20 14:42:42.5753 INFO Checking vMix server.
2020-07-20 14:42:42.5883 INFO Checking vMix server.
2020-07-20 14:42:42.6123 INFO Checking vMix server.
2020-07-20 14:42:42.6193 INFO Checking vMix server.
2020-07-20 14:42:42.6339 INFO Checking vMix server.
2020-07-20 14:42:42.6509 INFO Checking vMix server.
2020-07-20 14:42:42.6668 INFO Checking vMix server.
2020-07-20 14:43:02.5763 INFO Checking vMix server.
2020-07-20 14:43:02.5863 INFO Checking vMix server.
2020-07-20 14:43:02.6043 INFO Checking vMix server.
2020-07-20 14:43:02.6193 INFO Checking vMix server.
2020-07-20 14:43:02.6343 INFO Checking vMix server.
2020-07-20 14:43:02.6492 INFO Checking vMix server.
2020-07-20 14:43:22.5784 INFO Checking vMix server.
2020-07-20 14:43:22.5904 INFO Checking vMix server.
2020-07-20 14:43:22.6054 INFO Checking vMix server.
2020-07-20 14:43:22.6214 INFO Checking vMix server.
2020-07-20 14:43:22.6364 INFO Checking vMix server.
2020-07-20 14:43:22.6504 INFO Checking vMix server.
2020-07-20 14:43:40.3017 INFO Trying to send function <Function=StartRecording> in sync mode.
2020-07-20 14:43:40.3087 INFO Function URL is <http://127.0.0.1:8088/api?Function=StartRecording>.
2020-07-20 14:43:40.6670 INFO Trying to send function <Function=StartRecording> in sync mode.
2020-07-20 14:43:40.6670 INFO Function URL is <http://127.0.0.1:8088/api?Function=StartRecording>.
2020-07-20 14:43:40.8169 INFO Trying to send function <> in async mode.
2020-07-20 14:43:40.8229 INFO Function URL is <http://127.0.0.1:8088/api?>.
2020-07-20 14:43:40.8229 INFO Async function sended, result is "<vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.103302" meterF2="0.103302">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording duration="0" filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-43-40 p.m..mp4">True</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.1074829" meterF2="0.1074829" headphonesVolume="100" /></audio></vmix>".
2020-07-20 14:43:40.8379 INFO Updating vMix state.
2020-07-20 14:43:40.8379 INFO Creating vMix state form <vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.103302" meterF2="0.103302">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording duration="0" filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-43-40 p.m..mp4">True</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.1074829" meterF2="0.1074829" headphonesVolume="100" /></audio></vmix>.
2020-07-20 14:43:40.8379 INFO vMix state created.
2020-07-20 14:43:40.8559 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:43:40.8559 INFO Calculating difference.
2020-07-20 14:43:40.8679 INFO Updating inputs.
2020-07-20 14:43:40.8679 INFO Firing "updated" event.
2020-07-20 14:43:41.1827 INFO Trying to send function <> in async mode.
2020-07-20 14:43:41.1827 INFO Function URL is <http://127.0.0.1:8088/api?>.
2020-07-20 14:43:41.1967 INFO Async function sended, result is "<vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.04293823" meterF2="0.04293823">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording duration="1" filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-43-40 p.m..mp4">True</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.04702759" meterF2="0.04702759" headphonesVolume="100" /></audio></vmix>".
2020-07-20 14:43:41.1967 INFO Updating vMix state.
2020-07-20 14:43:41.1967 INFO Creating vMix state form <vmix><version>23.0.0.59</version><edition>Pro</edition><preset>C:\Users\Emisie\AppData\Roaming\last.vmix</preset><inputs><input key="bfe6a199-62f8-414f-9469-6aa8fa2fd253" number="1" type="Capture" title="Game Capture HD60 S (Video) (#01)" shortTitle="Game Capture HD60 S (Video) (#01)" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M" meterF1="0.04293823" meterF2="0.04293823">Game Capture HD60 S (Video) (#01)</input><input key="307a7a1f-b1a0-46f6-a584-5aba5d3cd560" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Stinger1" duration="1000" /><transition number="3" effect="FlyRotate" duration="1000" /><transition number="4" effect="Stinger1" duration="1000" /></transitions><recording duration="1" filename1="C:\Users\Emisie\Desktop\etapa 15 - 20 iulie 2020 - 02-43-40 p.m..mp4">True</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0.04702759" meterF2="0.04702759" headphonesVolume="100" /></audio></vmix>.
2020-07-20 14:43:41.2147 INFO vMix state created.
2020-07-20 14:43:41.2147 INFO Configuring to 127.0.0.1:8088.
2020-07-20 14:43:41.2147 INFO Calculating difference.
2020-07-20 14:43:41.2317 INFO Updating inputs.
2020-07-20 14:43:41.2317 INFO Firing "updated" event.
2020-07-20 14:43:42.5776 INFO Checking vMix server.
2020-07-20 14:43:42.5896 INFO Checking vMix server.
2020-07-20 14:43:42.6016 INFO Checking vMix server.
2020-07-20 14:43:42.6186 INFO Checking vMix server.
2020-07-20 14:43:42.6356 INFO Checking vMix server.
2020-07-20 14:43:42.6516 INFO Checking vMix server.
2020-07-20 14:44:02.5763 INFO Checking vMix server.
2020-07-20 14:44:02.5863 INFO Checking vMix server.
2020-07-20 14:44:02.6053 INFO Checking vMix server.
2020-07-20 14:44:02.6173 INFO Checking vMix server.
2020-07-20 14:44:02.6353 INFO Checking vMix server.
2020-07-20 14:44:02.6513 INFO Checking vMix server.
2020-07-20 14:44:02.6672 INFO Checking vMix server.
2020-07-20 14:44:22.5745 INFO Checking vMix server.
2020-07-20 14:44:22.5885 INFO Checking vMix server.
2020-07-20 14:44:22.6015 INFO Checking vMix server.
2020-07-20 14:44:22.6195 INFO Checking vMix server.
2020-07-20 14:44:22.6355 INFO Checking vMix server.
2020-07-20 14:44:22.6515 INFO Checking vMix server.
2020-07-20 14:44:22.6674 INFO Checking vMix server.
2020-07-20 14:44:22.6824 INFO Checking vMix server.
2020-07-20 14:44:41.1912 ERROR Dispatcher unhandled exception. System.NullReferenceException: Object reference not set to an instance of an object.
at vMixController.Widgets.vMixControlClock.Timer_Tick(Object sender, EventArgs e)
at System.Windows.Threading.DispatcherTimer.FireTick(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
2020-07-20 14:44:41.2352 ERROR Current domain unhandled exception. System.NullReferenceException: Object reference not set to an instance of an object.
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at vMixController.App.Main()
elgarf
#837 Posted : Monday, July 20, 2020 10:20:55 PM(UTC)
elgarf
Russian Federation
@Chircanu,
My inbox now empty. I still want to look at your controller.
elgarf
#838 Posted : Tuesday, July 21, 2020 11:35:15 PM(UTC)
elgarf
Russian Federation
Clock widget should be fixed now, I've also made some UI/UX changes.
Downloads
Universal Title Controller (updated 21.07.2020)
JAIRODJ
#839 Posted : Wednesday, July 22, 2020 2:48:03 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi, thank you for your work and the time you dedicate to it.
There is a downside.
If you put more numbers then the IP automatically closes.
for example .. if I copy the IP from vmix and paste in UTC, it would be a number like this: 192.168.100.5:8088
then UTC closes, does not give or time to delete 8088.
And for making a suggestion if possible.
Perhaps a form of datagridview could be used to observe the data that comes from excel or other data with names or texts ... it would be easier to access them and select the one that needs to be shown in a CG.
elgarf
#840 Posted : Thursday, July 23, 2020 2:24:14 AM(UTC)
elgarf
Russian Federation
@JAIRODJ,
I'll fix it in the new update, just thinking about what else I can do.
As for datagridview, I think, there is Data Sources into vMix already, and better use them, instead of external data into UTC. When I started UTC, there wasn't way to push data into titles, so I made simple example of XML data reader. But I'll think about it.
Guest (22)
