	Setting multiple output buses as default
 Joined: 7/1/2020(UTC) Posts: 6  Location: Glasgow Thanks: 1 times
                Hi - I have a setup whereby I have 3 audio output buses (explained below for clarity) and I was trying to work out if there was a way to make all 3 the default for new inputs? I can see how to change which bus is the default, but I want all 3 (Master, A and B). Is this possible?
  For reference - the Master output goes to my stream, A goes (via Virtual Cable) to a browser-based VOIP dialler into an audio conference call, and B is a loopback to the mixing desk minus the microphone inputs so that we don't get echo from the delays.
 Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
                Also, the ability to make C-G the default.
