wwdv
#1 Posted : Wednesday, January 22, 2014 3:29:55 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
I like to project our church beamer presentations over my camera image with alpha channel effect.
(both are coming in through the capture input)
The presentations have most of the time black or white backgrounds.
I did some tests with color settings black/white stretch and alpha, but my camera image is always getting lighter or darker and the text is not sharp.
Isn't there are more simple way to filter out the black or white background and project the letters on the camera image?
Chromakey is not working because the text must be displayed over the whole camera image.
Egriswold
#2 Posted : Wednesday, January 22, 2014 5:50:33 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
What you're asking about is known as a lumakey. This process requires two sources. First the image, Second the key. Which can be just black and white or shades of gray to vary the level of transparency.
At this time vMix doesn't support this feature. I don't know of any software based switching applications that does.
I would suggest if possible create your slides in a program such as PhotoShop with no background and export as PNG files to be imported in to vMix.
Best of luck
wwdv
#3 Posted : Wednesday, January 22, 2014 6:16:43 PM(UTC)
wwdv
Thanks, but I am not making the presentations by myself.
The (guest)speakers are bringing there own presentations.
The beamer output is captured as a video signal, so I've got 2 capture inputs to create this effect.
Should that also be possible with lumakey?
Egriswold
#4 Posted : Wednesday, January 22, 2014 6:41:10 PM(UTC)
Egriswold
Many have asked for this feature.
Mostly to support external graphic generators for animated titles and scoreboards.
From programs such as Casper CG
The down side is it would use two video inputs. One for the source and the other for the Key or Matt.
Egriswold
#5 Posted : Wednesday, January 22, 2014 6:49:15 PM(UTC)
Egriswold
Have you tried picture in picture ?
using the multi-view to place speaker in a sized down window over the text.
Also I have had the speaker stand in front of a Green screen and keyed them over a presentation
While sized and place in an optimal position. then I can fade them up and down as needed.
kind of like a virtual set but with presentation as the background .
#6 Posted : Thursday, January 23, 2014 7:03:14 AM(UTC)
Was thanked: 4645 time(s) in 1605 post(s)
If you can edit the presentations, setting the background colour to green and using the chroma key feature in vMix
will produce similar results to luma keying.
wwdv
#7 Posted : Thursday, January 23, 2014 6:37:21 PM(UTC)
wwdv
I can't edit the presentation.
I've only got the video output of the pc that is showed on the beamer.
btw. The presentation should always be on the foreground, not behind the speaker.
However, I got a nice result now with this settings (for those who are interested):
Beamer image color settings:
white text on black background: Black stretch=0 White stretch=7 Alpha=6
Black text on white background: Black stretch=242 White stretch=234 Alpha=10
Start the lumakey effect with start Overlay (Alpha=128) and effect duration=1000 for a smooth fade effect.
