Feature Requests
Better Internet navigation in vMix.
Joined: 6/30/2019(UTC) Posts: 9  Location: New Mexico
It seems when one is using the vMix and trying to show the audience where information, you are referring to, is in Internet, navigation of the Internet is very limited and is comborsam (at least for me)! Will there be a more robust upgrade to this part of the vMix so one easily can navigate the Internet and guide the audience to the proper page in Internet and where the information is in a page?
If a question is asked in a video page (for example in Youtube) and you can answer, show the related page in Internet, etc. and record it, later on, people with the same question can look at that answer in the video. This will be quite useful in the future for those who have the same question. They easily can follow your lead and see it in Internet themselves. -
Either learn how to use the web browser input (see help files) or even better use any browser and input as a desktop capture.
- Originally Posted by: ask  Either learn how to use the web browser input (see help files) or even better use any browser and input as a desktop capture. Thanks:). Do we have a video of how, what you suggested, is done? If I can learn this it will help me tremendously! -
Rank:: Advanced Member
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Can you use this URL: www.maitreya.org and see how it looks in vMix, for you! Mine, the navigation part, ends up to be very small to navigate (cannot see the links)! Howevers, the borders around the main navigating part are very large. Are the pages in your vMix, using the URL above, look ok, if yes: why mine end up to be so small! What am I doing wrong?
Originally Posted by: Mission_Of_Maitreya@maitreya.org  Can you use this URL: www.maitreya.org and see how it looks in vMix, for you! Mine, the navigation part, ends up to be very small to navigate (cannot see the links)! Howevers, the borders around the main navigating part are very large. Are the pages in your vMix, using the URL above, look ok, if yes: why mine end up to be so small! What am I doing wrong? You are not doing anything wrong , the webdesigner did . Suggest the design of the page might benefit of a bit of enlargement , its less then 900 wide !! of course one can zoom the input ;-)  church2.png (126kb) downloaded 1 time(s).
Originally Posted by: doggy  https://lmgtfy.com/?q=vmix+desktop+capture&iie=1 you couldn't explain it better -:)
It makes sense, thanks:).
Is there any way to solve this problem beside fixing the website (any workaround)?
The website is fine in the browser though, but not in vMix windows! -
Joined: 4/23/2017(UTC) Posts: 1,468  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
The webside in Chrome (outside vmix) is , hmm, from the 80'. Sorry. Maybe you try the browser zoom to render it bigger in the browser and then use desktop capture.
The website is fine in the browser though, but not in vMix windows! - like i mentioned before : zoom the input (vMix windows)
Feature Requests
