Automatically panning a virtual 4K input?
Joined: 5/8/2020(UTC) Posts: 7  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Scenario:
Input 1 is a 4K camera capture.
Input 2 is a virtualized Input 1, with Zoom level set to 2, X Position set to 1.
I'd like to write a script, triggered by a shortcut, so that the Input 2 takes 3 seconds to go from X Position 1 to X Position -1.
Is this possible with or without scripting? I'm a .NET developer so I don't mind (OK I mind a little) doing VB.NET.
Joined: 5/14/2013(UTC) Posts: 148  Location: uk Thanks: 2 times Was thanked: 26 time(s) in 22 post(s)
Try Using Virtual PTZ rather than virtual input and scaling and then use the Merge transition between presets
 2 users thanked Henny for this useful post.
Originally Posted by: Henny  Try Using Virtual PTZ rather than virtual input and scaling and then use the Merge transition between presets Nice, this was the secret sauce I was missing!
