jvphobic
#1 Posted : Monday, June 22, 2020 1:06:51 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
On the most recent Vmix version. Windows 10.
When I add a VST3 (tried 2 Waves and one RX7) to a list input, once the list moves to the next item it removes the VST3 from the plugins of that input. Can anyone verify if it is just me or if I found a bug in the system?
Thanks.
thanks 1 user thanked jvphobic for this useful post.
JMK-TV on 2/12/2021(UTC)
#2 Posted : Monday, June 22, 2020 3:55:57 PM(UTC)
This is a limitation of the List input, it doesn't support VST3 plugins at this time.
As a workaround you can use an audio bus instead and then route that audio bus to master.
jvphobic
#3 Posted : Monday, June 22, 2020 11:29:08 PM(UTC)
jvphobic
Thanks! I didn't see it in the Vmix manual anywhere. I will do that then. Thanks for the quick reply. As always, LOVE Vmix.
jvphobic
#4 Posted : Tuesday, June 30, 2020 10:54:47 AM(UTC)
jvphobic
FYI. That does work. BUT... I would love to have the option to not have to hear that bus then. Is there a way to mute that bus, but still have it come in to the Master? I am using it to auto level commercials with a VST3. But I don't personally want to HEAR the commercials being played.
321actionvideo
#5 Posted : Friday, August 25, 2023 1:26:04 AM(UTC)
321actionvideo
As a workaround, you can use an audio bus instead and then route that audio bus to the master.
I wish there was a way to know that we can't use plug-ins on a list audio input. I spent a whole day trying to get a plug-in from wave.com to work and was about to try to get a refund as I wanted to equalize video ads volumes that I have in a list, so I added the plug-ins as normal, but would get memory error and every time I did a search on that error, I only found was the video card was the error, so that lead me to update all the video cards, and still no luck. So I will tag that error to this post that I got so maybe someone else having the same problem will look here "Attempted to read or write to protected memory."
Once I added the plug-in to the bus instead of the list audio, it all seems to work now.
