Hylkewolf
#1 Posted : Friday, June 19, 2020 8:13:22 PM(UTC)
Hylkewolf
Netherlands
I would really like the option to have an external timecode input for the recordings.
Maybe it's possible through the mini-jack input.
And also i would like to have the option to scale the timecode and give it an external output.
In this way it can be send to a studio and others can check the time.
This can maybe be done in a combination with timers and countdowns.
zenvideo
#2 Posted : Friday, June 19, 2020 8:28:01 PM(UTC)
zenvideo
I don't think there's anything stopping you recording an LTC timecode feed right now, via a mini-jack or other audio input/interface. For example, route it as the only input going to group C, then select MABC as the audio sources in the Recording settings and you will have a recording with multi-track audio, including LTC timecode.
However, I suspect you're looking for something more complex than that...
